Hi all, technical and purchase question for those with a rear air bag delete (I am not a hard-core off roader and 90% of driving will be on paved road. I just want to be prepared for overloading and occasional bumpy adventures as I get into "embracing nature"):
- how important is having the top secondary spring (cone) as part of the air bag delete? Some of the air bag delete kits don't include it, or include it as a "stage". I know that in the 4Runners (which the GXs are closely related to) they have these cones as standard in their rear spring setup.
- if I do get cones, is it OK to get the Toyota OEM cones versus the aftermarket cones? The cost difference... is almost 3x. OEM cones cost about $80 and some of these aftermarket cones are like $200+. I know they have their technical differences, but for the most part, if the OEMs are good enough for a 4Runner, then I should be OK with them no?
- how many of you also switched out or cut down the rear rectangular bump-stops as part of the air-bag delete? I was thinking about replacing the GX bump stops with the 4Runner bump stops which are shorter. Metal Tech 4x4 has a video saying to cut the GX bump stops because they are too long and were intended as resting points for the air bag system.
Thanks in advance!
Thanks in advance!
