GX470 Power Steering Rack and Pinion
I would have personally added the GX460 rack to my rig if I had known it was an option.
Not saying it's bad, but you could buy a GX460 rack for less than half of just getting the base Toyo one and not have to ream spindles. It just requires the two mounting holes to be drilled out a bit bigger.
Do you happen to know what size the holes need to be drilled out to? And aside from the holes would this be a direct bolt on?
Would you have a recommendation for stronger tie rods that'd fit if I were to go this route?
This rig will eventually see 35s and will get used a quite a bit on trails so trying to replace parts with this in mind.
Thanks
The GX460 rack and tie rods are all bigger already, and when you order a rack from toyota/lexus you get new tie rods.
I used a 9/16 drill bit to open them up, and you want to buy two GX460/5th gen 4runner bolts and nuts to replace your old ones. The rest is direct bolt on. It's slightly harder to fit in as it's slightly bigger in most dimensions, but I did it in my driveway on jack stands without raising the motor.
If you want significantly stronger I think you have to look at doing a LC200 or Tundra rack. I don't really know the ins and outs there aside from more money and more things need changed.
Toyo also has a 5th gen rack with their LC tie rods that is another incremental improvement. I have heard a lot of people say only strengthening the ties rods a lot isn't the best idea as it will just move the failure to the rack, and at least a tie rod on the trail isn't that bad to do where a rack is bad (and who carries a spare rack.)
Thanks for the feedback. I am thinking about going this route. I also saw your write up on the swap, thanks for sharing.
How many miles have you put on the 460 rack? Any other issues to note?
Maybe 8000 miles, had it off road a bit including an off-road park. The ratio is slightly different but I adapted to the change within a couple days despite having this truck a decade.
My only issue that happened around the same time was the traction control sometimes beeped for a second when close to turning at lock and changing elevation sharply, but I know other people have had this happen too after various changes. I did a ZPC and it became much rarer and it doesn't cut power or anything drastic, it just is momentarily pissed off.
Hello all, I have a GX 470 07 model, it appears my power steering rack is going out, very vague steering. After reading the PITA of DIY I will take it to a shop, I live in So Cal. towing can really expensive but this will be difficult to find the right shop.
I guess there are 3 options.
Factory Lexus
CVJ I think they are called
460 mod
Stock vehicle full dealer maintained to 205K miles, 2nd owner.
So if I will have the rack and pinion replaced what else needs to be done at the same time?
My local repair has a off road euthanized and is is well versed in Toyota, they do allow me to purchase the parts or they can for me, I just pay the extra so they keep their margins. No worries there, I get it. It will be expensive, pay once cry once and get it correct.
Has anybody done a build thread for something like this.
I replaced my air bags, so even if I put new shocks on I will keep the air bags but buy the spring for future install.
Thanks in advance
Factory Lexus
460 mod
Thanks in advance
What shop in socal?
Sub'd
Thought this thread was about to pick up :) How about that 460 rack eh, @rommelrommel ? Still working for ya? Anyone else give this a go? Mine is leaking from both boots. Steering feels fine but I'm anticipating issues.
What shop in socal?
I went to Longs in Menifee off Ethanac and the 215 freeway, there is Precision Alignment and Brake in Temecula. Biggest problem with finding the right shop is before you need to tow it. I am sorry for ghosting this thread. My tires are shot and I watched for sales but I could not find anything but missed the sale at Sam's buy 3 tires and get one free, This rig is still a mall princess and I drive it about 5k a year. So once I get the ties and an alignment I guess I will find out what else is wrong with it. Full dealers serviced up to 205K miles with a few deviations.
I need to replace my Rack & Pinion on my GX.
Are there any recommendations on aftermarket Racks or should I just bite the Lexus price bullet?
Any "nice to know" tricks when doing this in my garage?
Many Thanks!
What’d you end up going with?
