GX460 trd Wheel Fitment Dilemma
Coventry
Hello everyone I have a 2018 GX460 premium that is currently stock. I have a set of 4runner TRD takeoff wheels with Nitto ridge grapplers 285/70R17 that I would like to install.
I’m looking to go with the Daystar spacer lift, (little to no off-roading). I am keeping the factory running boards. I would like to know if I need spacers or not to achieve this setup.
There was a picture of this setup in the GX460 picture thread but no mention of spacers or not.
I also have a 2005 4runner V8 with a unknown brand spacer lift with 285/70R17 on factory wheels with 1.5” spacers.
No spacer works with most 285/70R17 except some more extreme mud tires that have aggressive sidewalls.
Spacer would increase scrub radius and increase your rub potential. You would always want to max out your lower control arm caster setting and massage/pull the fender liner forward.
Do not cut the fender liner, especially the right front side as you would increase the risk of engine hydrolock due to OEM intake location.
First off, welcome to the forum and your new rig! :cheers:
Second, what I've written below is not to be drag or bummer, but a reality check for you.
Any reason you haven't just bolted them on in your driveway and rolled around the neighborhood to see how they feel and look?
This will answer most your questions you've asked and not have to worry if the info you're hearing on here is accurate or not.
The short answer from me, note this is my opinion:
Do not use spacers of any kind, either to lift your rig nor to push out your wheels.
You and a nice rig, it's a Lexus for heavens sake! Spend the extra cabbage and do it right.
Reasons:
  1. Doing a body lift, you'll have to deal with your radiator, shifter and other components having to be adjusted. Plus you'll see the vehicle's frame. Just doesn't look good.
  2. Doing a wheel spacer,I consider just plane unsafe. You'll need to do regular torque setting on the spacers bolts to ensure they haven't come loose. You're much better with just getting the right wheels and tires.
  3. Most anyone on this forum will attest that aftermarket suspension gives a better ride than stock if properly researched for the correct suspension for the build (or lack of build) of your rig.
Do it once and be done with it. The old adage: "buy once, cry once" is very true in this sport/hobby.
I really hate to be the person to be that thunder cloud over your parade, but I'm assuming you want the truth from a person who's built three overlanders over 30 years, including my current one here: R²M 2013 GX 460 Overland Build
So I know a little of what I'm talking about.
I think the TRD 4runner wheels have less offset, so that will get you good clearance to the UCAs most likely.
Then youll need to tackle the running board bolt, and massage the front fender liners a bit Im sure. You might even need to clearance the running boards "mud flap" area some since 285s are pretty wide.
Do not add spacers unless they hit the UCAs.
Id bolt em up and see.
Thanks
If you aren't wheeling and don't need the larger 285s, IMO you would have a much easier path keeping the TRD wheels but using 255/75R17 or a 265/70R17 tires instead, which will probably fit with less rubbing and no lift, while also affecting acceleration and braking less than 285s will. 285/70R17 Nitto Ridge Grapplers would probably be an easy set of used tires to sell if you went that route.
Yep, if they're 5th gen TRD pro wheels, they have +4 offset. Not sure which TRD wheels he's referring to.
