Guessing game!
OffGridOverland
Overland Anywhere - Anytime
Litchfield Park AZ
Website
www.offgridoverland.com
97 - 80 series
Lets have a little fun. Any ideas?
I found this in the lower oil pan tonight. No idea how long those pieces have been in the pan. As they can't drain out when changing the oil.
I should know tomorrow.
I guess swarf that's been in there since the engine was milled. I may change my guess if you put something in the pic for scale.
Yikes! Sections of lower piston skirt? Had a rebuild lately?
I am thinking this as well. Or a bearing. The crank bolt was way over tight.
Torque spec for that bolt is over 300 lb/ft - you think it was tighter than that?
I can't see scale but because of the vertical lines I'm going with piston skirt. But if it is, that cylinder would be a mess.
Yeah it was on way past that. It broke a few wrenches, The starter wouldn't move it. I had to use heat and a 4 ft breaker bar in a 1 inch drive. Then have another person hold the flex plate bolt /14mm socket as I bounced a few times with my full weight to break it loose.
So far the skirts look good. I'm headed out to drop the middle oil pan. Then pull bearing caps. I need to pull the oil pump down too.
The shop that worked on the truck 10k ago had all that apart.
The middle oil pan is loose. I just have to jack up the motor to get it out. Then I'm golden.
Were those aluminum chips from the front cover that got extruded through the timing chain / oil pump gears / ??????
Mains... 4, 5, 6 and 7
5 being the worst.
The crank has polish-able scars. They are really not that bad. The bearings took the hit.
The rods are perfect so thats good.
They said get a Land Cruiser. It will be fun. You won't need to touch it.. They said.. lol
