Guages quit working
Check the 15A gauge fuse in the interior fuse block. Mine keeps blowing as well (only sometimes when I shift into reverse). Still trying to figure out the source of the problem on mine though.
You probably have a problem in the back-up circuit. Do you have halogen backup bulbs or additional backup lights added to the circuit?
Dan, nope just have the stock ones, I also have some other behavior that I believe is contributing to the gauge fuse blowing.
1) CDL does not work, can hear click from relay in kick panel when shifting into low but no dash light.
2) Same relay clicks on and off rapidly (sounds like chattering teeth) randomly. usually starts after being on a rough road.
3) My A/T P light does not come on when the xfer case is in neutral and the tranny is in park.
All of these issues sound like their somehow intertwined, and I believe they are all on the gauge fuse (?). I realize the CDL is a common problem due to PO non-use. One more thing, how to I trouble shoot the CDL relay in the kickpanel, could not find a procedure in the FSM.
Well...it was the fuse....I feel kinda stupid! I checked that first and didn't see anything right away. As I had just picked it up at a body shop for looking at the drivers side door I took it back to them and they got the fuse replaced. Everything works now. I went out and bought some spare fuses to have just in case
Thanks for your help
