guages for a vortec
Fayetteville, Arkansas
I need to redo my entire instrument cluster and I am not sure what guages will work with the vortec since it doesn't have the traditional ways of finding engine temp and what not. I need to install everything speedo, tach, oil pressure, water temp, amp I think I can use about anything for the fuel guage from the fuel cell and the tranny temp guage. I have been looking at autometer but I dont' know what works with the vortec help me out here please
autometer
i use autometer guages.. with the 98 vortec that i have there all manual guages..
kevin
how do you hook up your water temp guage if it is the manual version because the vortec doesn't have a traditional thermostat, forgive me I have absolutely no experience installing guages
call autometer, they should be able to talk you through everything, they did for me. rpm can hook directly to the engine or your harness should have an output wire, mph you will need a VSS signal, not sure what tranny you are running? I am using a btb VSS signal generator that hooks to my stock TC mechanical sender hookup
Noah
