FJ40-GARAGE said:Its possible to get 5Watt Bulbs over here in Germany.
12 Volt 5 Watt TYP W5W W2,1x9,5d
Another Option would be LED Lights, they are pretty popular here and should be even on ebay in the states.
Hella now make the above bulb in a 6w xenon - got these for some markers - very bright!
Problem with the LEds is that they are designed to shine straight ahead (for putting in marker lamps etc) and arnt much good in a dash light where it's the sideways spill you want.
I put leds in my dash, but got actual LEDs and siliconed them so they shone 'across' the dash. Used 4 and it works really well, Didn't take pics when I did it (sorry!) I got 2 5mm, and mounted them at the bottom corners of the speedo, pointing up and across at about 45degrees, and 2 3mm, mounted on the inner top corners of the fuel and temp pointing down and out at about 45 degrees. I dont have amp and oil in my cluster anymore.
Put LEDs in all my gauges and saved about 40w - helps a lot at night with spots on and a std alt
