Guage Cluster Fix
Chesapeake, VA
Website
theshealys.com
Ok I hope this hasn't been covered before. I had this problem of not getting everything to work at the same time on my gauge cluster. Mostly it has been the turn signals. Not that big of deal. Today my oil pressure stuck at zero and fuel too. This got serious. I tried reseating my plug numereus times. No joy. So its time to remove the guage cluster and try to clean up the male pins. I ohmed out between (faceing the back of the guage) the lower right screw to the pin. That is the oil pressure guage. I had a open circuit. I then ohmed between the shinney part of the board below the pin to the screw with a dead short(good wire). Between the pin and board was open circuit.
That means that the pin must have been crimped on somehow and has worked it's way lose from the board. I checked other pins like the turn signal ones and they had the same problem.
I heated up my soldering iron and placed it on the pin only and use the solder between the board to make just enough to go between the 2. Hooked up with sucess.
Hope this helps someone not get rid of there guage for a small problem like this.
