Grounding Alternator case? N terminal?
Gig Harbor, WA
Anyone have a pic/write-up of how they grounded their alternator case to the block/frame?
Also, i read that the N terminal on the alternator that isnt used, can be used for an idiot light. Idiot light for what? And how? Because yes, i am an idiot:idea: And i could use another light:D
The alternator bracket is the ground between the case and the block. The quality of the ground is important, so Toyota also ran a separate ground wire (white with black stripe) between the case and the voltage regulator to be sure that the regulator sees the same ground potential.
The N connection or the common connection of the wye wound 3 phase stator can be used to monitor the power output of the alternator using a charge indicator "idiot light". It is used in Fj60s and other Toyota applications in conjunction with a different voltage regulator that has a relay built in for the indicator light. Look up a schematic for a early FJ60 to see how it is wired.
Thanks. I think im gonna try hooking up a charge indicator idiot light, since i seem to be having charging issues. It would be nice to know what my chargin system is doing...or isnt:frown:. Im starting a new thread on my charging problem, feel free to stop in and post pinhead:D
