Ground, Ground, Ground...
San Juan Puerto Rico
Website
www.facebook.com
My truck went to the shop today because it kept blowing the AC blower relay. After the relay was replaced, the mechanic told me that the reason for the truck kept blowing relays was that some of the grounds that go from the motor to the chassis were in bad shape. He recommended me to replace them all and to add a couple of extra ones for good measure. I'll follow his advice and see if this works.:cheers:
I'll probably make two, now probably it would be a good idea to use some heavy gauge wire...:cheers:
Didn't even gave a chance to make the ground; blew the relay... again#$@%^!!!!!:mad: Putting the new grounds this weekend and Monday going back to the shop, (warranty work).
can you tell which part # you are referring to with the blower relay? I may be having the same issue.
