I like a shaft rub as much as the next guy, but this is a bit aggressive for my taste. What's causing this and what do I do about it? Y'all think the drive shaft needs replaced now?
Running OME 850/860 with Fox shocks.Suspension lift?
Regards
Dave
Below is the sway bar (I think it's called). Only 2.5 inch lift. Drop blocks like these?What’s below that spot. My guess is you have a 4” plus lift? You need sway bar drops sir.
But that price is ridiculous for a smidge of square tube with two holes and some bolts.Below is the sway bar (I think it's called). Only 2.5 inch lift. Drop blocks like these?
never felt or heard a thing... silky smooth!WOW! You never heard or felt the rub? Definitely drop the sway bar I would spend some time under and see what’s binding. Regardless you need to drop the sway bar.
My opinion is to replace that drive shaft, the walls aren’t that thick and that looks like it’s almost chewed through.
I have a 1.5” drop on my 2” lift made from 16gauge square tube and $4 worth of bolts from the hardware store. I would recommend some thing a little heavier than 16 but a had it laying around the garage. And have not had issues.But that price is ridiculous for a smidge of square tube with two holes and some bolts.
I believe in the free market whole heartedly. I am just expressing my opinion of the value of this particular fleecejob. And I buy crap rather than making it almost wherever possible. I bought the slee washer bottle relocation kit for crying out loud.Totally!
...Unless you don’t have quick access to 2” box tube.
...Unless you don’t have access to a chop saw.
...Unless you don’t have access to a zinc plater.
...Unless you aren’t sure what hardware to use.
...Unless you just don’t want to think about trying to make your own solution and just get something off the shelf.
But cmon...
I cant stay mad at youI sell too many of my crap at a loss or even money. Let me have this one. Cmon, just this one. Think of my wife’s cat, hungry, mal-nourished. No mice in sight. Relying on the errant cricket. But only one set of FleeceJob Drop Brackets can feed a cat for one week. Think of the kitty won’t you? Try some kitty.
Starting to make sense now.... at least my solution, forgot I tossed the front sway bar in the trash.Really the amount of lift has little to do with it, more about allowed droop (shock length) and the amount of CC. We disconnect the sway bar mounts, fully droop the front axle (frame stands), then hold the sway bar up, attempting to remount it. Note the gap when the sway bar touched the drive shaft and make spacers ~1/4" thicker, or cut the sway bar mounts and weld them longer. Prefer to make them just long enough, have the bar tucked up as much as possible.
