Grinding sounds in reverse under load only
Vancouver Island
Hey guys, quick question
I'm a proud new owner of a 97 lx450 and I haven't noticed any issues until the other week when I was stuck in some sand and tried to reverse, when under load I heard a nasty grinding sound.. when switched into 4low and THEN reverse there is no grinding sound under load.
I take it my reverse gear of the automatic transmission is failing somehow?! Or is it may be a drivetrain issue?
Can anyone chime in on this?
Thanks in advance
I have to give mine a couple of seconds before I give it any throttle in reverse or it'll do weird stuff like that. It's done that ever since I've had it and it hasn't had any other transmission issues. Curious if it's the same thing and what causes it as well.
Thanks mingles this is exactly what I'm experiencing. Unfortunately there are not many answers in the end..
Anyone else experience something similar in reverse?!
If memory serves me correctly, there was a fix for this inside the valve body, I think. Some kind of a ball needs to be messed with, not sure exactly. Some people call this sound a "zipper" sound. My '97 had it also and it has something to do with the transmissions from '97 I think. Again, not sure of the exact details. Do a search and let us know what you find. I think @Tools R Us contributed to that thread.
My '97 LX450 does this under moderate load in reverse. Be kind with the throttle and it should be okay for normal use. When I tow my full size pickup bed wood hauler I always go low gear in the TX case when backing up. It's never slipped when in Low.
On a positive note, it's been doing that for the past 50k miles at least, so don't worry about it unless you need to back up a large hill every day.
