Gremlin - Can't locate noise
Today I removed the front driveshaft of my 1996 lx450. I've got a poppoppoppoppop noise during acceleration, primarily noticeable while making a right hand turn. The noise is still there even after taking the front drive shaft off. The u-joints were in great shape. The birffields have been serviced recently.
I have noticed that the rear driveshaft has at one point rubbed the exhaust. I've tried moving the exhaust over away from the driveshaft as far as I can. Near as I can tell, the u-joints on the rear drive shaft seem fine. The 4x4 H and L work great.
The popopopopopop noise happens more frequently after the engine is warm. I'm stumped. The noise stops after acceleration. Down the highway it's fine. Thoughts?
lock the center diff, put the front shaft back in, and take the rear out. See if noise stays.
With the drive flanges still on, the birfields are still going to rotate even with the driveshaft removed. Sounds.like the birfields are not properly lubricated or are just plain wornout.
If I ride the brake and hit the gas I can replicate the noise with the vehicle barely moving and the front driveshaft removed. I'm convinced it's in the t-case or in the rear of the drive train.
I'm thinking U-Joints on rear DS.
Could also be pinion bearings in rear axle. Check oil in rear diff and look for metal shavings. Then do what @bloc said in post #2.
