Greasing the Birfs
Nashville, TN
My birfs are a little noisy on turning... Marv @ Specter Offroad said you can grease them without taking them apart (he said they are probably dry)? I crawled under and can't seem to find a grease fitting anywhere in that general vicinity... anyone know? (1996 FZJ80)
Also, when the truck is jacked up, I can move one wheel over an inch before the opposite wheel begins to move... leading me to believe that my front end "clunk" on acceleration is not the ring/pinion as I suspected, but rather the birfs... If it was ring/pinon, the 2 wheels would turn at the same time and the slack would be before turning the driveshaft, right?
Little square nut on the top of your birf. Take it off and insert greese gun into hole. Fill it up to about 1 inch from the top.:beer:
Yes leave the wheels on.
Sit on the ground infront of your truck and the nut is on the about 3/4 the way up the brif. i have a grease nipple i put in there so i can pump it up. i also have a nut near the bottom so i can remove the old grease.
jono
Just to be clear, the front axle is on jackstands and you're rotating one tire an inch before the opposite one rotates, correct? This seems pretty normal to me. There is slop in every mating surface and there are a lot of them.
Certainly shoot some moly grease in the steering knuckles, but keep an ear out as well.
jono
to NZ cruiser:
Which nut where on the bottom to remove the old grease?
Note to the OP: get an extension for your grease gun tip; I use a 3 inch (metal) needle nose type available at NAPA; about $15; that way you can stick the extension about 3 inches into the inspection/fill port and get more grease down where it needs to go. If you just stick the grease gun nozzle at the face of the port, the grease may build up near the hole and appear like you have filled the knuckle up, but not.
You must use a MOLY fortified grease; I use the Valvoline Palladium available also at NAPA, about $3 a tube. It has 3% Moly. If your birfs are completely dry, you will need at least three tubes. I recently let mine get too dry; they took almost four (4) tubes over two weeks before my clicking went away, but it did go away. The only drawback of filling them to the brim is that you will may get some grease pushed past the axle seal; no big deal IMO; just check your front gear oil in a couple of weeks, and if black and frothy, just drain and refill with fresh gear oil.
There are many ways to do this and many opinions, some say don't fill it all the way up. IME, if you don't fill it up, less (or very little) will get where it gots to get ie: around the balls and cup of the birf. You can pump a tube and a half in each side; then go for a drive in a large empty parking lot. After I grease my knuckles, I then drive in circles (as above) right and left, both forward and backward with the steering wheel turned full each way, etc; to help move the grease around. If anyone is watching you do this, suggest you not stick around as it will appear that you have lost your mind to someone who does not know what you are doing;)
Good luck
i have the bottom nut added when i had the birfs off, made the regreasing job easyer
When you make a turn, and your birfs makes a clicking noise, you better check your bearing. This is what happened to me on the passenger side. :whoops: Heard a clicking noise when I made a turn, after wheeling.
I did this today! And thanks to everyone on here, my noise has almost completely gone away. Appaently my birfs were getting dry on my 97 and I was getting ready to do the full service and may have to do it anyway but for now this has solved the noise problem. I put a 1/2 tube of moly grease in each side and went for a test drive. The sound has almost gone away. I plan to check mine again in a few days and probably will need to add more. OBTW, I found it easier to just remove the wheels and be able to access everything. I think I may still have a bearing issue on DS but I will deal with that soon. Thanks everyone!
SC
