Grease Inner Wheels
Hey guys,
This may be a dumb question, but what's wrong in these pictures. I don't think there is supposed to be this much caked on grease. Two days ago, the grease on the drivers side started melting and dripping in the driveway. What do I need to do? When I first got the cruiser about 4 months ago I was going to clean it all off, but decided against it thinking it might dry something out if I sprayed degreaser on everything. Don't mean to sound dumb, any help is appreciated. 94 cruiser 4.5 liter Thanks.
Uploaded with ImageShack.us
You have a blown axle seal, that's gear oil. Looks like you have an axle rebuild in your very near future!
Couldn't find a larger pic?:hillbilly:
Axle seal is leaking, causing what is commonly called "birf soup", time for a reseal job.
That makes sense. Sorry bout the pics, just use image shack to get them on the forum, don't know why they are so big. So what could I expect to pay a shop to replace the seals. I guessing they both need to be replaced? The passenger side is not dripping, but is caked up. Or, how much more work is it than putting new rotors on. I did that myself, and it wasn't too bad, and I think i did everything correctly. Just don't have a lot of time, even on the weekends. What other stuff would need to be replaced. I replaced the out bearing bc I messed them up getting them out when I did the rotors. In the meantime, should I check the diff. oil level everyday? Thanks.
axle service
Dealer wants about 1300 to do the rebuild (local quote)
I bought the kit from Dan for 250, included the axle nut tool.
I also bought the 100 series spindle bearing/ bushings to replace the 80 series brass bushing. That was another 105.00 (dealer wanted another 300 for that to do it during the rebuild.
took about 12 hours to do the job, 60 bucks in grease and diff oil, 5 rolls of paper towels, 4 cans of brake cleaner, and 200 latex/nitrile gloves (harbor freight).
good times.
the rear is next, it will be a joke compared to the front...
here are the threads you need to read and print:
https://forum.ih8mud.com/80-series-tech/78276-front-axle-rebuild-faq.html
https://forum.ih8mud.com/80-series-...ssembling-birfield-inner-axle-assemblies.html
I am halfway through the rebuild my self and its pretty simple. (I had no clue what I was doing before I started) I had to buy all the tools also and I am still going to be way under what the dealer wanted to do it. This way I also get to know the truck better. If you get all the stuff you need it could be done in a weekend or one long day.
Here are a few sites I used to figure everything out:
Toyota 4WD Front-end Maintenance - Solid Axle - ORN
https://forum.ih8mud.com/80-series-...-service-almost-done-few-final-questions.html
This one is not the full process but it has a lot of Pic's:
The Toyota Landcruiser Owners Club :: View topic - 'how to' guide - LC 80 hub strip down & cv change ...
Also elmariachi has a DVD that lots of people think is a must for a first timer!
https://forum.ih8mud.com/sale-parts/42722-fj-80-steering-knuckle-rebuild-dvd-2.html#post5493027
Hope this helps
Cheers
Well, I ordered the rebuild kit from Cdan. Should be here tommorrow, so I'll be workin on the cruiser this weekend. Not apprehensive after reading the helpful posts on here. You can't really tell bc of all the sludge, but one of the four studs that mounts the steering arm to the housing backed all the way out, hence the enormous amount of fluid loss. There was another one that was hand loose, and the remaining two were loose, but not hand loose. I feel really lucky to have caught it before a disaster. Question is, is there a gasket of any kind between the steering arm and knuckle? Thanks in advance.
I did my front and back axles last christmas. I recommend the factory service manual if you can get a copy, if not the posts are pretty good. The nice thing about the FSM are some of the techniques and torques needed.
Otherwise, I recommend give yourself plenty of time and enjoy it. Having the experience makes it real easy to crack'em open if you need anything else like a gear change or installing a locker.
Wow, I've never seen one that bad :grinpimp::beer:
Congrats on your imminent first birf job. It's not difficult at all--just messy.
The knuckle studs are one of those things that I check after/before every major trip. They have been known to loosen on occasion (as you've experienced).
There is no gasket between the birf and the steering arm, but there are some thin shims that are specified and set at the factory. I've never replaced mine--even though they're a little rusty--I've just cleaned them up and reinstalled.
Do yourself a huge favor and get some degreaser or engine cleaner and head to the self-serve car wash and get it as cleaned up as you can before you start working on it. But...make sure you've enough axle fluid in that diff!
