GOT manual antenna option for the 100 series.
If you run your power antenna all the ay down with the dash button, everytime you start the truck the antenna will only go to that spot.
How does this option compare to the Tundra manual antenna? I have the Tundra setup and was going to install soon but is this is a better option or might fit better... well then....
Looking for an manual OEM option to replace the factory auto antenna that I continue to destroy. Im hoping there is a JDM option available someone knows about.
I would replace the mast with this one. If you are really looking for a manual antenna, then disconnect the power to the motor and cut the plastic tooth section from the mast.
YES!!! Right here, this is what I am doing next time. Once you install their base you can even use a standard fixed mast antenna instead of their shorty antenna.
I have seen videos of guys just screwing a fixed mast into the broken power antenna base and wondered how well that worked. If it came off in the carwash or what.
I took the lazy mans way out again and replaced the mask. With Ms LCP help 7 minutes and $17.63 more to Amazon.
MTC 86337-60151 Antenna Mast Toyota Land Cruiser 1998-2007 9099
