Like every truck that lives or lived where the roads are salted in the winter, my truck has some serious rust. I was under the truck doing something and I noticed that the USPS rear quarter was in bad shape. What made it a problem is that there were holes rusted through the inner, outer, and wheel well panels, and where I drive off road there are some deep water crossings. I don't want water in there because that is where my amp lives. Here is what the panel looked like:
So I hunted around and found some sheet metal, and gathered some tools. Here they all are:
The sheet metal
My little plasma cutter and welder:
And I picked a nice selection of hammers for shaping the new panel:
So with all that, I started by fixing up a makeshift metal brake so I could bend the 90 degree bend for the bottom of the new outer panel, what would become the new metal in the pinch weld. Here is the makeshift metal brake:
Nothing too hellafied there, just two bits of angle iron in my 4" vice. Once I made that bend I was ready to take the sheet metal to the truck start shaping it to match the curve of the quarter panel:
From here I just started bending it using a tiny little anvil, a bit of old 2X4 wood, and whatever else I could use with my collection of hammers to make the metal take the shape of the panel. I didn't do any compound curves, that made it MUCH easier. To avoid having to make any tricky shapes for the outside panel, I decided to cut the replacement panel like this:
The crud you see in there is a mixture of rust and mud. Ih8mud! But there is lots of mud here and precious little in the way of big rocks and desert. The wires you see are for the controller for the trailer lights. What I found when I opened this area up is that there are four trapezoid shaped plastic covers that fit over openings in the bottom back cross-member of the body; you can see them by climbing down where the spare tire goes and look back at the cross-member that is connected to the floor of the cargo area. These openings, two on each side, allow access to the fasteners for the tail gate hinges. Well, I was missing the two on the USPS. When I went into deep water, it was pouring into those openings, carrying lots of mud with it, and flowing into the lower rear quarter panels. Nice huh?
So now I cut the inner panel, and the part of the panel that fits in the wheel well. Then I started replacing the metal, beginning with the inner panel:
This panel is stamped in a corrugated fashion, and that makes it a bitch to fab. So I just started tacking it in and this is how it ended up:
Next I trimmed the first piece of metal I shaped to fit in the opening for the outer panel. After some trimming with the plasma cutter and some more shaping with a variety of hammers and things used as makeshift dollies, here is what I had for the outer panel:
Next I tacked and trimmed the inner and outer panels together. This was tough because the inner panel was wavy from following the factory inner panel, but it had to be flat at the pinch weld. So I hammered and trimmed and clamped and bent and this what I eventually got:
Then I had to make the piece to fill in the wheel well area. The spot where the three or four pieces of metal meet is tough, and so is the mess I concocted:
Here is the outside of the roughed in piece:
And
and
So then I used my grinder and sander and then sprayed some bed-liner stuff on it:
And then some white paint:
Here is the crap I cut out:
I had the inside of the truck back there gutted out and sprayed rubberizer and bed-liner liberally all over the inside of that section of the truck. Basically everything from the tail lights to the rear door was coated. This was a fun little project. I know that the repair is ugly, but it is hidden by the plastic piece of the bumper. Now I can ford deep water without worrying about flooding the quarter panel.
The welder is a little Lincoln 135, feeding .035 wire w/ shielding gas (CO2 & Argon). The plasma cutter is a cheap little thing I got at a tool sale. Dang thing cuts through much thicker steel than it's supposed to. I am not a body repair tech (should be obvious from the pictures), I just did what I see the folks on Spike TV doing every weekend. I don't think I would attempt to do this on the hood of my wifes truck, she'd kill me; but for a sopt that can't be seen it's a serviceable repair.
Thanks for looking, and I appreciate your comments.
Best regards,
Wes
The sheet metal
And
and
Best regards,
Wes
