So I asked around and did some google searches for driveline work. I had a gnarly vibration after my OME lift. I suspected U-Joints. Long story short, I had a badly bent rear driveshaft that really started talking after the angle change.
There's a place called Maestro Muffler and Driveline, 902 W Hatcher Rd, Phoenix, AZ 85021. They have excellent online reviews so I called. When I called and explained my issue they said not a problem, bring it anytime.
When I arrived, the mere appearance, location and amount of homeless people hanging around almost changed my mind but if you go, don't let that fool you.
The driveline guy, Ron, knows what he's doing. He had me drive my 80 on the rack and immediately checked pinion angles and found them to be within spec. He pulled my rear driveshaft and found bad U-Joints. He replaced them and tried to balance it and coudn't after many attempts to straighten it. So, he fabbed me a new one with Spicer U-Joints (which I like cause I can service/replace them myself easier).
$237 fabbed, painted, installed and out the door in two hours. He is knowledgeable on DC shafts, high pinion angle jobs etc also. He is adamant about not installing or selling something that you don't need. He did not charge for the work on the bad driveshaft nor the other U-Joints he installed to test it.
It made the Mt. Ord run this past weekend with no problems and 99% of my vibration is gone. (I suspect the other is in the front)
Try them out and tell him I sent you as I'm going to have him do my front shaft as well.
