Going turbo this summer..
When I get off deployment and am back in the states I am going turn my FZJ80 into a turbocharged beast.
I have looked at the available production exhaust manifolds and will likely make my own setup..
I am thinking of starting with the stock manifolds making use of what I have spent on welding gear over the years as well as my know how of aircraft exhaust systems.
The turbo will be a twinscroll turbine housing.. for a reason. Each modified OE manifold will have its own side of the turbine housing. So 3 cylinders will feed a half of the twinscroll turbine much like volvo does on their inline 6's.
There will be a slip joint where the pipes from the manifolds meet the twinscroll mounting flange , a ball joint where at each manifold and there will be a nifty tripod brace system to the block supporting the turbo.
The wastegate will be mounted to the end of a short Y that has a slip fit where each end meets its own secondary and another slip on it's outlet on the way to meet up with the dump-pipe.
Mild steel slips and balls dont cost that much and some general aviation components cost much less than the nearest speed shop equivelent. They give and take a little and that means no cracks and doing things twice.
I already know where I will get the T4 divided flange.
Turbo Flanges
Also where to get the slip and ball joints. Same operation different markets and websites.
Aircraft Exhaust- custom built aircraft exhaust | Aircraft Components
For the rest of the exhaust I will have a 3" mandrel bent over the frame system. Aftermarket HDJ80 exhaust.
Next big item.. Intercooling. I considered air to water but its a PITA.. It would mean that I would have an affordable mini radiator for it in front of the engines radiator to get bashed instead of a an IC. However I think I can protect an air to air IC from stones and still get air to it when mounted behind the grill that is behind an ARB.. Between the IC and the grill I will make a guide vane grid that aligns airflow with the slots in the IC and the guide will take the hits that get past the rest of the front hardware.
jgwinc surely was on the right track.
https://forum.ih8mud.com/80-series-tech/190765-newbie-pix.html
I do think that if he had lowered the static compression with a thicker head gasket and used a stand alone engine management system (not emanage) with a knock sensor he would have not broken a rod. Other than that everything else was dead on. The engine build up looks imacculate.
I put well over 100hp thru stock rods on my last turbo car but I had a full EMS, Knock monitoring/limiting, and ran my wideband 02 for a closed loop tune full time. I am sure the OE rods can handle the 100hp each with good tuning (no knock/detonation). They just dont have the oops margin a forged set has. The 1FZFE is much like a larger, tougher less ****py 6cylinder version of a mitsubishi 4g63 four banger.. Hey look.. A 1FZFE has oil squirters to cool the backside of the pistons just like the turbocharged versions of the 4g63.
Pics from another 1FZFE boost junkie found here.
Anatomy of a 1FZ-FE (yes-I finally took it apart) - PerformanceForums
Here is what our stock rods look like..
The piston also looks pretty good. The top ring is dropped down a good ways from the crown which means that the ring runs cooler.. Turbo engine pistons have grooves set like that.
It may not be made from billet but I know for a fact they are a better rod than a stock 4G63 rod. Also keep in mind that the guy that tore down this engine pictured above was hitting 20psi and had the head gasket let loose. It was the first time he tore down the engine so those parts have been ran hard. Simply put, good tune thru a good EMS an fuel system = no problems with the 1FZFE IMHO..
See the o-ring groove he added to the block deck? He went with a copper headgasket he had made. Well I wont get one made or o-ring anything. There is a SCE brand gasket called the ICS (Integrated Combustion Seal) Titan. They make it in a bunch of thicknesses for the 1FZFE.. It does not need an 0-ring cut in either the deck or the head. Check out SCE's site as I have a ton to cover already..
As for turbo selection I think it all comes down to a GT4088R Garret.
I used this calculator at this link.. In fact clicking this one will load it with a 1FZ-FE stats in place already.. It will have 2500rpm entered but change it and the boost etc as needed.
Not2Fast: Turbo Calculator
Anyhow I checked out two different pressure ratios that equate to around 11psi and 18psi then checked each from 2000 rpm to 5500 rpm in 500 rpm steps. Then I did one at 5800 which is what I remember the limiter kicking in at. Been months since I drove it being in Iraq and all.
Then I plotted it on the compressor map I got from garret
Happy holidays!
Sounds you have done some homework on this.
Good luck and can't wait for the build.
Subscribing
Buck
Thanks guys.. I get to see a couple different models of cruisers over here that did not get sold in the US. Hilux's as well..
I will be picking thru components and then ordering online a week or two before we pull stakes.
I await your build! Turbo seems like a good option of keeping the awesome I-6 smoothness and longevity at the expense of gas mileage. Of course, a V8 conversion would do similar things for you in the power department and get better mileage, but dropping a chevy into our 80s doesn't sound real appealing. Did you ever consider doing a transplant?
And just like another ultra-beefy Toyota Inline-6. ;) IMO, the 1FZ is essentially a big block 2JZ. And given the power numbers SuperCrown was able to extract from his setup before it finally popped, I'd say the output potential with a factory long block is pretty much the same.
I like the idea of spooling each scroll of a large single with one bank of cylinders and had considered that with the 1FZ. In the Turbo Mustang world, guys who build cheap junkyard setups using huge-hotside diesel turbos often block off one scroll completely with positive results. With a properly sized single, utilizing both scrolls would be ideal, especially since the stock exhaust manifold layout and the firing order are already in our favor.
I've pondered on the intercooler setup several times and still haven't decided on one, but I think I'm leaning more toward methanol injection than using a core of some sort.
Let us know what you end up doing as far as engine/knock management. As of now I have no idea which direction to take in that regard. On one hand I think something like a MS+S setup would be ideal, but I'm not sure I'd want to start from scratch like that and potentially compromise reliability.
Just curious, were you referring to a Volvo truck engine with the twin-scroll turbine setup? AFAIK, all the I-6 gassers were TT.
Excellent research so far! :cheers:
nice nice .. I hope it fucntion perfect .. it's a big turbo .. to make top hight end powa !
A twin cam 4.5 engine is an engine that can take in a bunch of air.
If I went smaller.. Like a GT35R Garret's largest medium frame turbo... Well I ran a PTE SCM61 on a Mitsu 4g63 which is the compressor wheel from a GT35R. It was a bushing turbo with a single scroll mitsu pattern flange PTE custom cast housing on a 2.0 liter engine. It would reach the 20 psi range when the little 2.0 was turning 4k rpm or more. It is a pretty good compressor side but one problem. The not2fast.com calculator says the compressor wheel is too small to feed our 4.5 liter engines to redline no matter what we do on the turbine side.
Ok so on the GT37 is Garrets smallest large frame turbo. Interesting... Even worse of a fit than the GT35R.
I plotted one line at 2k RPM from about 6psi (5.5 + .5 ic drop) to 18psi (again 17.5psi .5psi IC drop) and the same pressure ratios at 5800 rpm.. If a GT35R will work it will be not by much at the limiter with minor induction mods and if someone did their work and homework on the head and valvetrain the engine will be asking for flow way to the right of the chart.
I know the GT4088 spools decent on a 3.0 inline six toy and can flow what I need at 5800 rpm on the 4.5 liter. With twinscroll, ball bearings and the right turbine housing it should spool pretty quick on the 1FZFE.. It wont hit surge on the 4.5 either so it is not too big. The line I drew on the GT4088 compressor map that crosses the surge line was 2.5k RPM and the plot ended at 18psi. It wont hit 18psi at 2.5k rpm. Even 10psi at 2000rpm is like 400ft/lbs tq and just about 158hp. Heck 5.5 psi at 2000 rpm is 340 ft/lbs tq. Those power numbers are calculated based on guesses for BSFC and VE.
Nope the V70 T6 car has this setup now.
Smart thinking.. A good engine management system will protect parts worth far more than its own cost. I am looking at BIG STUFF 3
http://www.bigstuff3.com
http://www.bigstuff3.com/gen3featurecom.pdf
http://www.bigstuff3.com/gen3pricecom.pdf
http://www.bigstuff3.com/proc.pdf
It is not plug and play for the 1FZFE so I will have to build an adapter harness and do a bunch of setup with my laptop pluged into the ECU.
I want a bunch of features MS+S would not get me. Our engine has two knock sensors on it already. I will just add a wideband o2 sensor and some egt sensors.. BSIII has individual cylinder fuel and timing control. So you can address uneven EGTs
Looks like I might o-ring after all
SCE Gaskets Inc.
It seems that on ten head bolt V8's they say to use their other gasket and o-ring it. The number of bolts around each cylinder on a 1FZFE is the same as one of those..
So the standard Titan gasket and an o-ring job is what will need to happen.
V70 T6? Just looked it up.. didn't even know such a thing existed! Very cool.
The BS3 setup looks promising.. the knock management is a nice bonus. I see it also has an optional boost controller.
Isky will loan you the groove cutting tool for about 60 bucks, IIRC.
Go Guard!!! Hooay !!! I wear a bow and arrow patch. Nice Rig. Mine is still stock. But not for long.
Thanks for the info on the groove cutting tool.. Is the Isky tool for the head, block or either?
BS3 is John Meaney's personal baby. He started the whole gearhead tunable EFI craze many years ago.
I will look into the boost control with BS3 some more but on the AEM we just ran a GM boost control solenoid. Basically the ECU can open, close or pulse the solenoid to control the pressure signal to the wastegate. There are some fancy things it can do.
I have really been kicking things around.. I might just rebuild the engine with forged rods and pistons during the summer months when the cycle gets the most miles put on it. I can fix the teeny dribbles from the oil pan and the microscopic amount that is coming out the rear main.
Mostly it things like it being easier to mount the head on a head studded block when it is on a stand and not in a lifted truck on 35's. Plus I want to either put a bunch of upgrades in the slush box or find the appropriate manual transmision the beefy 151. I am leaning towards keeping the automatic for sure and just beefing it up big time.
Might as well overhaul it...
jgwinc Was running a T04Z...
He had a ok spool with a handlefull of PSI off the line against the tq converter.. The GT4088 will spool sooner.
To illustrate how much bigger his turbo was I have plotted the TO4Z map from 7psi to 30psi.. He did run it at 30psi a time or two which explains the OEM rod failing... I'd run them at 20psi with great tuning fearlessly.. 30psi... nope..
Anyway.. Here it is dwarfing the GT4088R
Block only: http://www.iskycams.com/pdfcatalog/2004-05/page16.pdf though I'm not sure a receiver groove in the head would be required..
It will be interesting to see what you do with the auto. Unfortunately I think that's the weak link in such a setup. I believe jwginc said he spent around 5 grand on his auto.. :eek:
Yeah I saw that. If you pay someone else they get spendy quick.
I think I will just build up my own. Get the parts and DIY. I have done a few TH350, TH400, TF727, 700R4, and even a 4l80E we put some better planetaries in.
Good clutches, steels, clearances right, valvebody upgrade, big ass cooler, good transfluid.
I will also be looking into ways to go easy on the trans during shifts and make up for it afterwards.
To get everything working I will need to keep the oem EMS running but not actually controling the engine. I will just let it think it is since it is the easiest way to keep the rest of the systems happy.
A reciever groove is not needed in the head according to SCE. They dont say if it will hurt and or how much it would help over and above just the deck. They do say that you can just do the head and wire it instead of the block deck and that it does not matter which one of the two you do.
