Glow Screen timer mod
Silly question - where is the Glow Screen Timmer located on the BJ 74 ? . If I knew where it was I could do the overide with the NCS.
It's under the dash on the passenger side. You'll have to take out the plastic glovebox insert to access it. Do a search on glow screen over-ride...Stickboy originally came up with the idea of using a NC switch to fool the timer into thinking it's very cold outside.
*EDIT: Thread now included in the FAQ under Engine.
Location of glow screen relay
Would that be the same on an HJ61?
I can't find it on the drivers side with all the other relays.
Thanks
Tim
Getting back to the KISS prinicipal, Peters idea sounds great and even improving on that idea with a adjustable potentiometer.
I like it.
Rob
brownbear said:
ok, don't put in a resistor, put in a potentiometer or rheostat
and control the glow screen to whatever you find is a better mix. potentiometer is better as it is ajusted with a screw and a rheostat generally is a dial and knob.
but both should work as you say.
Cool mod.
Perhaps a silly question, but do the normally aspirated cruisers use glow screens as well, or glow plugs? If plugs, ether might not be the best solution for cold starting.
-kevin
-kevin
Ether is not recommended by many on a 3b.
