Glass Breakage Sensor / GBS Location Question
Cincinnati, OH
Where is the GBS physically located, I need to increase the sensitivity of the GBS. The manuals on the slee site don't say.
Wasn't aware the 80 came with a GBS.
-Spike
The sensor is the tiny 1/4" round speaker looking do-dad on the same switch plate as the alarm light. I don't know if it can be adjusted. The FSM for the alarm goes into great detail and is a book in itself. Don't recall it saying anything about adjustment, but I just skimmed through it. Sorry, not home right now to look...
The FSM also states that it is tuned for glass breakage only so in theory you could have your dog barking in the car and it wouldn't go off. Haven't tested that theory yet...
I have a factory alarm and that little speaker looking thing near the alarm status light. On the slee website it says that the glass breakage sensor should be adjusted so that when someone taps on the glass with a key, the alarm should go off. It mentions adjusting a knob on the GBS.
If IIRC it's under the drivers seat.
On mine, the glass breakage control unit, the thing with the sensitivity adjustment, is inside the driver's side kick panel. It is wire tied to the wiring harness. I had to remove the false pedal, then one screw holding the kick panel in place.
The ECU is under the driver seat on mine. Not sure how to adjust the sensitivity though.
Here are a couple pictures of the defective one I replaced. I am not sure if there is a difference between the security systems in the Lexus and LC. I do have the RS3000 unit under the drivers seat.
