Gifting a set of wheels , not sure the if the size is ok....
So Cal
So my father likes the black rhino wheels armory. And here are the specs
16x8 -10 offset, 4.11 backspace, 112 center bore
My question is iknow 45 require a backspace of 3.50... this wheel should fit ok right?
He has a 77 el salvador truck.
If it’s a South American truck it will have front drum brakes which will work fine with the wheels specs above.
it would be a no go with disk brakes.
Actually he got the truck, it had already been converted to front disc. It should still be fine right. It currently uses some steel 16 inch wheels.
Thank you for such a quick response.
Oh I see you already answered the question. I'm sorry. Amd thank you once again. I just got excited about getting him the wheels.
Thanks again
