Getting ready for winter
Saratoga Lake, NY
I have the back end of my truck apart and also doing some under carriage scraping and painting getting ready for salt. Even painted the rear mudflap letters in white. Hope it helps.
So there is a plastic piece or cover that covers the four holes in the rear bumper from left bumper to right on the LX450's, would that piece fit on the Land Cruiser?
Here's a couple shots of the truck body with the rear slider housing in really great shape. I was surprised actually.
But, the aluminum window frame in the last pic is beat. Should I keep the window glass and buy a frame, or look for the window and frame together in the classifieds?
I have the weatherstrip for both sliding windows. Part# 62742-60040 is driver side? Correct?
Buy a replacement unit from a used supplier.
@arcteryx
@slow95z
Or keep the glass and get a new frame. Perhaps spray I little paint on it before installing
When I was a younger lad I had a winter beater. I worked on it all winter, the heat wouldn't work half the time bla bla bla. I need reliability and comfort now. So unfortunately this is my winter beater, and has been for 14 years.
Looks like there was some tape covering a couple openings in the aluminum window frame. Should I retape before reinstalling?
There were little pieces of clear plastic with some adhesive on one edge. Don't remember what I personally came up with as there purpose. Like a check valve of sorts foe water to drain or to keep the aluminum from touching the steel? Anyhoos, you can get those pieces from Toyota if you want to install the frame with them.
Found the part number in one of the online part dealer diagrams but dont recall the name or number.
Unfortunately, best winter prep is taking it apart every couple of years and redoing it.
fluid film I'm sure is great but I hate to work in it. Sanding is everything.
Then priming and painting with what ever you think is good is the way to go. But you need to get the rust out. I have CLR on my list to try this year.
