Getting new tires.
Will my '91 turn 33" tires without gears, or should I stick with the 31"s for now?
Andrew
go bigger....
I'm running 315 75/16 (35inch) BFG MT's without gearing and all seems to be good. Might see some degredation of braking, but the cruiser doesn't get up to speed to much where I live in the northern utah mountains...also haven't seen any really negatives running this tire size while wheeling. I would like to go up to 37's, still contemplating the cost of all that and would most likely have to regear...maybe 5.29's...
Oh, one other thing...this all assumes you have some type of a lift. I don't know if 33's will rub without a lift or not.
Yes, I will post there about borrowing tires, I think for advise in general my time is better spent here.
I'd like to qualify my statement earlier about the 80 being under powered. That said, it is has plenty of torque at normal freeway speeds (60-90mph), just very light on the get up and go. It is a dog to stop and I intend to repair/replace the breaking system before upgrading the tires..
Thanks
Andrew
I'm in Houston, in Midtown. I just got 33s Hankooks MT on stock suspension. So far I'm satisfied with them both on and off road. PM me if you want to check it out.
go bigger....
Where in UT do you live? I'm wondering how a an 80 on 35's would handle going up Parley's Canyon with stock gears.
I have 33"s and they're great. Then again, I live in the land of Oz. Kansas that is, not Aussieland. My 33"s are fine for driving. I don't find the 3FE underpowered. (I know, I must be crazy; and I'm only a 23 year old kid to boot. :)) Also, I have never had a problem with 33"s rubbing. As far as I can ascertain, the FJ80's sit an inch or two higher than the FZJ80's so the 33"s don't present much of a problem as far as rubbing. I would say go for it. My next set up is hopefully a Isuzu 4HE1 hooked up to my A440, with OME heavies front/meds rear and 34X9.5 Michelin XZL's or just BFG AT's again. Good luck old bean.
33's should turn just fine. I have heared 37's are the point where you start needing gears. My friends 80 keeps up just fine with 35's vs. mine with 275's
DOn't forget, this guy has a 3FE....advising 35's with stock gears is probably not the best advice.
x2. I ran 35's for a few days while my buddy got his truck inspected....erm....*cough*cough*....
I blew through 1/2 tank of gas in one day. 60 miles (GPS verified) :eek:
I have a friend who has an 80 with a 3FE and has run 35's on it for over 2 years with stock gears and it runs fine. Granted the gas goes a lil faster and it is a sminge slower, but who drives an 80 for fuel economy and speed.
side question on tires....what size is a 295??
What about lift? will they fit on stock suspension?
So the general consensus is that the regular 33x10 or 33.10.5 bfg's (whichever they are) will be ok with stock gears?
Next thought that pops into mind. What kind of fuel economy can one expect with 31's or 33's in low gear running down the beach?
Read: how much extra fuel do I need for a 120 mile run?
a
I am running 33 STT on my 91 and they are great. I am getting about 12 to 13 on highway.
I also got the 2" ironman lift from ebay for $450 shipped and it is great. (flame away but I am not wasting money on OME)
It is a perfect setup since I don't know right now how I am going to set up the truck.
It is nice using the live.com 30% discount so my tires were $580 shipped and lift a tad over $300.
I have some and live in Montrose. Actually, I am about to move to some new tires. The BFG AT are moving towards the end of their life cycle soon. Expect to have them pulled off soon for replacement.
I might be interested in those. I could have a buddy pop them on my wheels for little/nothing. I had been considering getting a set of steel wheels for the offroad tires, is this a good idea?
a
Where did you get the Hankook MT's??? I couldn't find them around town, and ended up putting on 295/75/16 Nitto ATs. And the 295's run 33.6" (I believe) in my stock set up. I think they work because they are still only 11.4" wide. Here in the Houston sun baked roads, less touching the road, means less to melt off.
