Getting my Tach to work....
Merced, CA
So I have a 85 FJ60 that the PO swapped a 3B into.
He left the FJ gauge cluster in, and the tach doesn't' work. I have the cluster out of the diesel.
It won't be as easy as swapping in the diesel cluster and hooking it up for everything to work will it?
Am I better off leaving the FJ cluster in and running a after market tack?
If I do that I'm thinking of installing my pyro gauge where the factory tach is.
Thoughts....
Thanks,
Tim
It has to be a diesel tach
If you have the diesel cluster why not use the Diesel Tach in your gasser cluster and run the wires from the tach knock sensor on the bellhousing to your diesel tach in your gasser cluster ?
its pretty simple to connect the factory BJ tach.
1.You have to use the tach from the BJ cluster in your FJ cluster - its easy to swap.
2.You need to have the tach sensor in the bellhousing. Its on the passenger side probably directly behind the down pipe from the manifold.
3. Assuming the wires from the sensor are not connected to anything; you need to connect one of those wires to ground, and the other can be connected to one of the wires that was connected to the coil on the passenger inner fender. This way there is no wiring to change in the dash. Get a factory manual for your year and look at the wiring diagrams in the back
Well I got lucky!
Took the diesel tach out of the BJ cluster
Thanks Tapage:beer:
then when I pulled the cluster in the truck hook it up and it worked!!
No need to crawl under the truck!
Thanks for the tips Lynch....just got lucky didn't need to do anymore than step one.
Would have been easier with out the one year old crawling around the truck hiding my screw driver and screws....I ended up putting the original tack back in and getting everything hooked up on accident because he was getting into eveything!:mad:
In the end all worked out!! I had assumed it would be more complicated.....we all know what happens when we assume...well I learned it on Barny Miller but anyway!!
Tim
