GERRRRRTT!!!!!?????
Texas
PFA
IH8ers, I need some help. I “have” a noise in my front end that is pulling fibers out of my brain. It makes a GERRRRRT sound. It’s makes the sound for only a second, then disappears. It sounds like a bearing is grabbing ahold of a race and spinning it inside my front diff. Here’s where I get pissed. I drive from my house just north of dallas, to my in-laws just west of Austin. Approx 220 miles. It didn’t make the noise 99% of the drive there. When I get within 1/4 of a mile from their house, it made the noise for the first time. It did it several more times while driving in the area over the next few days. When we left to go home, by the time we were 20 miles into our trip, it drive perfectly fine, and has been silent since. Their house is in the hill country so there are some fairly steep inclines to drive up and down. Where I live, it’s flatter than Carrie Underwood. I searched the forum decently and couldn’t find a match. Next step is draining diff and transfer case. I serviced my transmission yesterday, with a new filter and fresh fluid. Fluid looked fine, not burnt with minimal material on the magnets. Anyone else have this issue? TIA
TLDR: noise, help, GERRRRT for only 1 second, only while in the hill country of Texas, yes I’ll have to go back in the 80, front end, sounds like a race is spinning in the diff, drives fine everywhere else.
Downhill, foot off the accelerator? Noise for about 2 seconds?
now that I think of it, I don’t think it has ever happened going uphill. Always downhill. May only be a little bit of a downhill grade, but never uphill.
My plan was to tear the front diff down after I serviced my transmission. The dude at the parts store ordered the wrong part. When we finally got the right part in, it had the right filter but wrong pan gasket. I didn’t want to have more than one thing torn down at a time. It kind of screwed my weekend up.
If you don't have a switch then you can shift to low range which locks the diff then pull the fuse and shift back to high. There are numerous threads that you can read about drive flange diagnostics, locking the center etc.
I my Grrrrrt is from a worn slip yoke. I hear it at slack throttle and when coasting downhill. I was convinced it was coming from the front end, but it's actually the rear driveshaft making the noise. New (old) driveshaft and new u-joints in the works.
Front driveshaft components are not happy. Grease them up with red tacky Lucus to hide it but with our rigs the front doesn’t rear like to get lifted past 3 inches unless the right caster correction are installed. Even with the right caster past 4 or close to 4 inches a double Cardan will help tremendously.
U-joints...infamous grrrr. Lots of reading on here about that.
I read a long thread about the “grrr” noise. The way it was described in that thread(at least the way I understood it) was that the noise was constant. Mine literally sounds like my front diff is about to come apart for about a second, then stop.
Grease the UJoints in the driveshafts and then possibly the spindle bushings. Did you service the front axle recently?
I did. It was very clean fluid. I saw nothing to raise any concerns. Everything looked fine. I grease my driveshafts about every 2k miles. It shouldn’t be a grease issue.
I will look into this. Thanks.
