General a/c work
San Antonio
My ‘99 has only ever had a compressor changed out and soon will need a new one. Is it best to change out a lot of the other components while the refrigerant is out? Or should I see if anything leaks while under pressure and only knock those out? I want to prevent having to discharge multiple times but also not go overboard on parts.
Did the compressor fail? is this a second unit that you are replacing? More info. would be nice. If the compressor failed were bearing materials came out you should replace the condenser and flush the lines all the way from the expansion valve. Hope this helps.
Compressor didn’t fail and only works at higher rpm’s. I think this is the second one and am unsure what other a/c components have ever been changed out.
