gearing for dummies
Pendleton Oregon
Website
www.oregongrain.com
I have a 79 FJ40 that is slowly evlolving into my trail rig. I went on a run with the local cruiserheads this weekend and found out I need better gearing etc.
Here is what I have.
March 1979 FJ40
Stock 2F
Stock Transmission
Stock Transfer Case
3.73 Gears
2.5 Inch lift
34 10.50 15 LPBs (currently running 255/85/16)
I have all these parts in stock and would like to use this set up. Is it possible? Would this setup give me a nice blend of onroad - offroad. I would be keeping it all toyota and not having to spend too much on it. Thoughts?
H41 Transmission
3 speed transfer case
4.56 gears
I run that exact setup with a lock right in the rear and like it very much, 1st is pretty low for the street but that's what second is for right.
35" tires and 4.56 gears, wheel it hard with no worries.
Hi All:
Bull, I'd suggest a gradual approach. Swap in the H41 tranny and see how you feel after taking it on a trail run. The 4.56 R&P gears would probably be a great swap, but I have a feeling that you enjoy the "overdrive" effect of the 3.73s on the freeway! :grinpimp:
What do you think of those Super Swamper 34X10.5 LTB bias-ply tires after a mixed trip of high-speed freeway and low-speed trail running??
Regards,
Alan
Josie'sLandCruiser said:
Hi All:
Regards,
Alan
I actually hated the 3.73s on the highway. Gutless turd up the hills..
With my current set up I was at 25 to 1 crawl ratio..
I would rather swap everything at once since I will be in there :flipoff2:
You've got all the parts, do it you'll like it. :D
Rodney,
I am not surprised at your hating the 3.73's with tall tires: out of the power band on hills.
I think you are on a good track. I have the H41 and 4.88's with 35ish tires. I went from 4.11's all the way to 4.88's. At the time my reasoning was if I was going to swap gears I wanted jump the next step and really notice the change. The 4.88's are great on the trail but I feel I am too low for the street now. If I could wave a magic wand I would wish for 4.56's but I am not going to go through all that work.
In your case you have high 3.73's so switching to 4.56's sounds like a good bet. Why don't you try driving my 40 and test out the H41??? The H41 is a great tranny IMHO. First gear is way lower but second and third are lower than the US H42.
The Orion is nice but they are expensive and there is the famous "popping out of gear" issue that many of us are dealing with. The last two years of the 3-speed J30 case are the strongest. Some guys will say the J30 is weak but you will not be pushing huge tires with a V8.
I think 4.56 gears, a nice H41 and a 1973 or 1974 3-speed J30 tcase would be the ticket. It is almost impossible to build a 40 with perfect street, highway, and trail gearing without spending a fortune. Your shopping list will be simple, all Cruiser, and not be that "odd ball system" when things happen on the trail. You will not be looking for adapters, new drive shafts, 5 speeds, cross members etc, etc...
Again, let me know if you want to test the H41 with 4.88's to compare with your current setup...
Max
It's on!
CruiserMax said:
Rodney,
Max
Max I have the SOA FJ60 that has the H41 and 36" tires. The first gear is nice even with the bigger tires. Maybe when we do clutches I can beat on your 40 a little bit :grinpimp:
Rodney,
Are you planning on taking the H41 from the 60 series and dropping that into the 40? Good H41's are getting harder to find. Most of these units are shipped used from Australia. You will then have options for a transfer case: your stock 4 speed case, find a good J30 3 speed case or adapt the "splitcase" from the 60. This third option may require cross member work and a reconfiguration of the parking brake assembly. Then there is the Orion option if you are feeling "lucky" and don't mind spending the cash...
Max
CruiserMax said:
Rodney,
Are you planning on taking the H41 from the 60 series and dropping that into the 40? Good H41's are getting harder to find. Most of these units are shipped used from Australia. You will then have options for a transfer case: your stock 4 speed case, find a good J30 3 speed case or adapt the "splitcase" from the 60. This third option may require cross member work and a reconfuration of the parking brake assembly. Then there is the Orion option if you are feeling "lucky" and don't mind spending the cash...
Max
I have a good J30 transfer case too :)
So here are my options with crawl ratio. I'm not looking for a rock crawler. That wouldn't fly on the NW trails, but I would definately want some more grunt and less wheel spin than I do now. Options below
Current Setup
Stock Transmission 3.555 1st gear
Stock Transfer Case 1.959 Low
3.73 Gears
34 10.50 15 LPBs (33.6")
Crawl Ratio 26 to 1
Choice A
H41 Transmission 4.925 1st gear
J30 Transfer case 2.313
3.73 Gears
Crawl ratio 42 to 1
Choice B
4.56 Gears
Crawl ratio 52 to 1
Choice C
Orion Transfer case 4.0
3.73 Gears
Crawl ratio 73 to 1
Choice D
4.56 Gears
Crawl ratio 89 to 1
How does your 3rd gear feel right now? You'll get 1.519(ish) with the H41 vs 1.41 on the H42. That and how much overdrive you're getting from the 34s would factor into your choice of diff gears. If you drive it, streetability is a consideration.
playing with numbers-
2nd
h41+3.73=9.86
h41+4.11=10.86
h41+4.56=12.05
h42+3.73=8.55
3rd
h41+3.73=5.67
h41+4.11=6.24
h41+4.56=7.93
h42+3.73=5.25
4th
h42+3.73=3.73
h41+4.56=4.56
You can see that the H41 with 4.56's in 3rd gear is approaching what it feels like with the H42/3.73 in 2nd. Not quite but in the neighborhood.
I guess my vote would be for 4.11s, H41 and the Orion. If no Orion then maybe 4.56s. The Orion with H42 is interesting- 3.73s give 53:1, 4.11s give 58:1. If you were on 35s or 36s, then 4.56 would fit better to me.
I am at about 50:1 (60:1 not factoring the tires- SM420, 4spd case, 4.56) on 35" MTRs and it feels great for crawling. Would be fun to have a doubler in there but it hasn't seemed necessary yet in the snow or on the Rubicon. The problem with the 420 is spacing between gears isn't that great. 3rd gear is good up to about 40mph and the rest relies on the 2F's torque to pull hills.
2nd
h41+3.73=9.86
h41+4.11=10.86
h41+4.56=12.05
h42+3.73=8.55
3rd
h41+3.73=5.67
h41+4.11=6.24
h41+4.56=7.93
h42+3.73=5.25
4th
h42+3.73=3.73
h41+4.56=4.56
Thanks for the numbers. I can see if I went the original route I would be geared too low.
