Gauges location.
What about this Madman one-for-all multigauge?
Engine Monitoring Systems - MadMan EMS1 Engine Monitoring System v1.13
They also offer specific senders kit for the 1HD-T and 1HZ engines.
TOYOTA Sender Kit - LandyOnline Shop
A couple guys from my club have ordered them after we had a local supplier stop in at a meeting to tell us about them.
They are quite nice, but I think I want the regular gauge look, escpecially now that I've seen some links here on decent pricing for some nice gauges.
Our man in the land of Mr. T (Mot) found that. It's a little pricey at $185 I think he said, so I'm still browsing.
I've been looking around some aussie forums, but its quite odd, doesn't seem to be a lot of options for 80 series. Lot's for 70's and 100's tho.
I take several month to decide what to use .. not really much options and the top of my old model dash isn't the best place to make nothing fit ..
Check these out. Din mount that are tilted toward driver
I have the madman installed, works perfect and has alarms you can set to whatever value you want so there's no need of watching the ffin gauge continiously. Pressure gauge left of the wheel was already there when I bought the car.
I don't have a boost gauge but I stuck my digital egt meter in (well, behind) the opening for the hazard switch, which I relocated in the bottom of the dash in one of the empty spots. I'll try to find a pic but needless to say it's brilliantly clean and practical :D
here goes
Whoops sorry forgot the linkhttp://
cgi.ebay.com.au/2-triple-gauge-dash-mount-turbo-silvia-skyline-wrx-sti_W0QQitemZ150351109518QQcmdZViewItemQQptZAU_Car_Parts_Accessories?hash=item23019fdd8e&_trksid=p3286.c0.m14&_trkparms=65%3A1%7C66%3A2%7C39%3A1%7C240%3A1318%7C301%3A0%7C293%3A1%7C294%3A50
http://www.glowshiftdirect.com has RHD and LHD pillar pods as well as other universal pods. I ended up with a triple gauge single DIN mount plate. I installed it "upside down" so that the gauges would face the the right. I'm pretty happy with it.
I have the same plate .. and when I make the measurements .. it don't fit. Now I see it take a little of the stereo space .. and in my case it don't allow me open the stereo face ..
It is definitely not the best fit for this application. I too have a flip down stereo face. It works fine but the alignment isn't optimal. I plan on shimming up the stereo to bring it further forward. I'll also cut the plate a bit to make it fit better. But for now it suits my needs while I work on fixing other stuff.
anyone find anything yet?
I am trying to figure out how to mount a few things
i am planning on installing 4
-EGT
-Boost
-auxillary tank fuel level (wvo)
-aux tank temp (wvo)
possibly in the future a tranny temp gauge
I mulled this over for awhile and decided on the solution in the attached pics. I liked the idea of hanging them from beneath the dash behind the shift levers but there appears to be a vent behind that lower panel. Also, mounting them behind the levers anywhere would require you to remove them if you need to remove the shifter console or center console.
Decided to reposition my gauges from the side of the tranny shifter cover to the top. They fit pretty nice and are much more out of the way now.
