Gauges dead
Midland, TX
I have a 76 and only my ammeter works. My other gauges are staying far left or low, no movement . No action from grounding sending wires either
Any ideas?
Thanks
Is this rig new to you? Have those gauges worked since you've owned it?
If you don't get any rapid respones,
there's a good thread you might search for
enter Posted by member: BJ40green
use search terms: clusters gauges speedo
It has been this way since I got it.
Thanks
Edit: BE SURE you disconnect the battery before pulling your cluster... or chance frying your harness
The ammeter is fed by the 10ga W and WL Wires, which run from the alternator to the fuse box, with a branch to the ammeter
The gauge “round connector” is fed, via pin 3, from the LR wire, from the ignition switch.
The ground is pin 1... check continuity on both wires to the “round connector”.
Also check/clean the contacts on the ignit
Rudi’s gauges,,clusters and speedo thread —> Clusters, Gauges, Speedo & Odo meters
