Since there are so many mods and swaps the issue of gauge/sender compatibility often comes up
Do you know the specs for a sender or gauge? If so post it up
Also the ammeter is an issue, I was researching if it was possible to mod an ammeter from an internal shunt to an external one? Still working on that. If anyone has an old ammeter that is not working they are willing to part with let me know cause I'd like to tear one down and experiment with it
I am thinking it may also be possible with resistance to double the range in the ammeter and turn 0-30 to 0-60 or even 0-120 as long as it is no longer wired in series and all of the current does not need to flow through it
In the following post there is some info from Stewart Warner on checking the fuel sender range which I thought was useful --just check the ohms and move the float with a wire--pretty simple!
At least with that you can compare senders.
