Gauge Madness!!!
Ok where to begin...Most of my gauges are acting screwy....The speedo is fine but the oil pressure, water temp don't work and the fuel guage will work sometimes...any ideas out there I've replaced the oil pressure sensor/switch on the oil cooler...I don't know...please help!!!
Oh yeah This is a 76 2f engine in a 75 cruiser
Thanks in advance!!!
If they all stop working simultaneously, then there is probably a bad connection at the fuse block engine fuse. If they are flaky independently then it could be a bad connection anywhere from the fuse block to the ground.
Don't feel bad. My oil pressure gauge stopped working on the way back from a trail ride and it started working again 30 miles later.
lol yeah sounds like my fuel gauge....the oil and temp never worked i'm not even sure about the wires
On the oil guage, it either connects to a bell thingy under the oil filter or if you have an oil cooler it connects to a bell thingy on this. The thingy is like the sending unit. My wire has a connecter on the end that can plug in 2 ways. 1) push the rectangular end (female) onto the male end on the bell thingy. Or 2) push the slot up onto the knob on the bell thingy until it hits the hole in the slot. Only method 2 makes mine work; method one must ground it out because the guage stays all the way to the R when plugged in this way. Hope all this high tech mechanic talk helps you.
What color is the wire that connects to the oil pressure sending unit...where doest it come from can you take a picture???`
Generally it is yellow with a black stripe.
yellow and black huh....I wonder if anyone could take a picture of there engine bay in that area so i could see where it's comming from and what it all should look like
come on no one knows well can anyone please take a pic of there stock 2f engine on the left had side of the oil sender so I can see where it's wire is coming from
Dont have a photo handy, but it is one single wire that is yellow with a black stripe. it has a female spade type connector on it. Put your hand on the top of your oil filter, then work your way down to the very very bottom, there is one small brass type nub. This is where that wire clips in. its the same type of conenction that is made on your brake master cylinder with the two green and white wires at the very bottom of your brake master. Same type of connector too. This wire runs all the way back to your instrument cluster and bolts into the back of the oil pressure guage.
Hope it helps.
The problem was my guages weren't connected to their coresponding switches / sensors and after some advice from here and alittle tracing I got them all rewired...
But now I have another problem.....they all work when they are working, meaning they all work together and decide to stop working together, Most of the time it's at start up if I Turn the key to the on positon *sometimes* The fuel guage will start to move if that happens then I can start the truck and all of the guages will work *but sometimes* they will stop working while driving, and then most of the time none of them will work at all.....any ideas.....
Next time they quit working try wiggling your ignition key a little if they go back to working you have a bad contact in your switch. Otherwise it's got to be your engine fuse block connection as mentioned earlier or a ground problem.
I've tried the wiggle the key method but it doesn't seem to work as well as switching between off and on and then most of the time that doesn't even work it's pretty random when they work and when they don't
So an update on this I've noticed two things that make this situation odd one is that after getting gas all guages always work...the other thing I noticed was that sometimes when they are working they'll just stop and all of the gauges will slowly go back to zero/bottom whatever so yeah what could cause that and why would they work everytime I get gas
