gauge issue
wierd gauges????
under normal operating circumstances
temp is pegged
fuel is empty
oil pressue does't move (low)
if i dissconnect wire from temp and hook it up to 12v.
temp moves to low???
fuel reads about right
oil stay the same low.
any ideas?????
I'm sure someone will correct me if I'm wrong, but it sounds like a short. Since temp is pegged and fuel is empty, that makes it sound like it is getting too much current = short. Have you checked all your connections on the back of your gauge cluster?
Good luck!
Your fuel gauge is reading resistance not dc voltage, I don't think I would hook up 12 volts to it to check it, there is 12 volts at the gauge, but your are putting voltage to the sending unit, that might cause a problem.
