Gauge cluster swap
Lancaster, PA
All,
I have a nice shiny '79 cluster that I would like to put into my '74. Everything looks the same except for the ammeter connections. There are connections for a 3 prong plug where my '74 has 2 wires that connect to bolts.
Does anyone have any info on whether the clusters are interchangeable?
I found one thread on this that mentioned '72 as the change from a screw on speedo, and '74 for the change to the plug - but no mention of the ammeter wiring.
https://forum.ih8mud.com/40-55-series-tech/20467-1972-gauge-cluster-1980-fj40.html
74 uses a voltage regulator and 79 does not i think they are wired a little different .maybey put the 74 amp gauge into 79 cluster good luck
Maybe the '79 has an external shunt? Be my guess.
if you look at a wiring diagram...the third wire is for the headlight highbeam indicator....
edit: that's on a a BJ, sorry, I just came off nights, thought I was in the diesel section, my bad....
