- Joined
- Aug 12, 2007
- Threads
- 963
- Messages
- 19,507
So what do I need to buy to make this change besides your barrel connection? New sending units for oil, fuel and temp?i offer the Round Cluster Meter 60180 New Barrel Connectors & the 3Pin needed Service Spec. Connector too ....
please send me a PM , i can help get you on the right path related to Painless and my 100 % Period Correct OEM-Type Cluster Service Spec. Connector Plugs , and there Color Code Tracer Stripes Wires / Leeds
So you would rather have a worthless 50 Amp Ammeter then a voltmeter that comes on almost every modern car? ok.
Ammeter vs. Voltmeter: Which is Better?
A voltmeter and ammeter are to an electrical system what a pressure gauge and a flow gauge are to an oil pressure system: A voltmeter measures electrical pressure in volts; an ammeter measures electrical flow in amps.www.hotrod.com
Amp Gauges vs Volt Meters...Separating Fact From Fiction
If you own an antique vehicle built before 1965 chances are it has an amp meter in the dash. One thing you need to understand is wha...fifthaveinternetgarage.blogspot.com
Ammeters became obsolete with new alternator charging systems. If you still have a generator, an ammeter would be the way to go.
This 83100-60180 barrel Connector kit comes with a 50a AMP meter connector pigtail as well
hooking up the 50a AMP meter requires More then just this Plug ,
and whatever u do DO NOT simply hook up your 30a AMP ring terminals to the back side studs of your new 60180 , u will
fry the new unit if u do
View attachment 1897768View attachment 1897769View attachment 1897770View attachment 1897771
ToyotaMatt
I ordered a set of these. Hope you have included some type of instructions. Looking forward to getting them.
Fantastic!! My truck is a '78. I'm new on MUD so need to know how to PM you?Have receieve your oder
i hand make each one to your paticualr production ate land cruiser
ALL WIRES are Labled PER and same in kind as the corosponding EWD for that year
What year is your truck ?
if you DO NOT have a FSM EWD manual , time to find one that suits you best
Pm me any further questions Please , as always im here to help ...
thanks
this is My version of Cluster Meter Reality , and barrel plug lay out ...........
View attachment 2784637View attachment 2784638View attachment 2784639View attachment 2784640View attachment 2784641
