I would think upto 78 except that the later ones 67? and up have a standing seam around the middle where your straps will hit. you could bend it over where your straps go. seen it done before. gas tanks are something I'd rather not modify tho.
others here have both pros and cons on the plastic tank, usually trouble with sealing around the sending unit.
You can sorta make a later tank work. it will fit in the hole but the filler pipe is different and it wont want to hit the hole. 9/72 and up are all the same, I think, not sure about 8/72 and back but I know they are the same until '69 or so and maybe furthur bcak.
