Gas Tank Size
matt32
I make the smoked meats
Mt. Olive
Okay I have a 92 FJ80 that only holds 20gal. do i have a bad tank, an aftermarket tank, or were there other options available? how hard is it to replace a or clean out a tank?
The official capacity is 25.3 gallons.
The "light" usually comes on with ~5 gallons left.
If you panic and fill when the light comes on, there you have it.
After the light comes on you can play a game of chicken with yourself to see how far you can get.
haha, is that from the first second the light flickers on or once it's solid hahaha. I play this game waaaaaay to much. Lost once....as I was pulling up to the pump thank god.
My experience has been that a "flicker" will take ~19 gallons and a "solid" will take ~20. Of course the "solid" assumes that you fill soon after it stabilizes, Your mileage will vary and my "sample" is quite small (one vehicle, owned since new, every ounce of fuel consumed recorded).
Once you have established a fuel consumption trend for your particular vehicle you will be able to guess at how far you have to go, once the light goes on, before you are on foot.
if you wish to fine-tune your range you could pack a spare can with you and drive til it quits. I do not recommend this since the fuel in the tank cools the pump and if there aint no gas the pump gets hot.
Not to mention picking up crap out of the bottom of your tank and plugging the fuel filter.
Not an easy part to change, either.
Haha good info. It varies so much here due to the mountains and the up and down I drive at times, but this was good to know! Thanks!
Isn't that what the sock is for? ;p
Not for YOU guys. :flipoff2:
I usually travel another 20-30 miles after the light goes solid. I did run out of gas once, right as I was pulling into the station. Engine was sputtering while driving toward the station and stalled as I pulled in. :doh:
Yup, but the sock doesn't catch everything. ;p
I did that once too. :doh:
If you have sediment in the tank, your going to pick it up regardless of tank level. Even when completely full, the fuel moves, sloshes with each turn brake, etc, much worse when off road. This is a non issue to running fuel low.
