Gas Tank Installation
Looking for a little direction on the installing a new gas tank. Everything is new but doesn't match up. HELP!!! Dutsman
Okay, I searched your other post and you appear to have a '74 - that would be under the pax side seat. Keep bumping it around and it will line up. I had to play with my new tank a bit to get the drain plug to line up with the hole in the body. Also, what are you using for spacers under the tank? If whatever you're using is too thick it may not fit.
