Gas Door Cable (Cdan please read)
So you know when you pull the gas door release lever? well one day I pulled it pumped my gas and then found out the gas door wont shut again. Im assuming the cable that runs that little plastic prong that keeps the door closed has broken because it doesnt stick out anymore. Anything else I should check? Ive dealt with it for awhile but I want to check and see how much it would be to get that replace and how hard the install is. Cdan can you help me out?
Which way did you come in?
:D
Haha hopefully the way that gets me a 2$ part and a 20 minute install time. Got any info on this part? Im going to consult my FSM now.
FSM has it listed as the Fuel Lid Opening Solenoid.
Bah dump dump bump....
Heh
Dan, while you're in that part of the fiche, what is the price on that little plastic part at the gas door hinge that pushes the door open when you release it? My bro in law's broke at 300k or so and he (horrors) has to actually pull his gas flap open at gas stops. Thought I'd restore it to proper 80 level operation.
DougM
DougM
Mine broke also (GASP) but I figured Id check to see the price on it. Maybe its cheap and worth the repair.
I've had this issue too, my prong was just stuck. Lubed it with some silicone spray and it started working again. I think you can access the linkage and spring for it from the jack/tools compartment.
DougM
X2 this has just recently started happening with my rig and its kinda irritating. Looks like the little thing just snaps on the inside hinge and provide the umph to push the door out when the release is pulled. Tired of prying the little bastard open. Course I think thats happening here due to the recent cold.
DougM
Take a peek at this thread.
https://forum.ih8mud.com/showthread.php?t=89182
And as Dan said:
"Replacing that little bastid is a chore.....:mad:
It's cheap but it makes up for it in agrivation.......:flipoff2: "
And he's not joking...
Nak
The part number for that spring is 77360-22020. List $3.60.
guess its time for me to get an order of some shizzle together. 3.60 aint quite worth the trouble so I'll have to order other stuff......................
oh shucks.:D
Gas Flap Spring Mod
Or you can make your own spring that will never fail. I used 3 teeth worth of a timing belt from a '91 Ford Escort carefully trimmed.
I first did this on the '92 we used to own when the little metal spring vanished. The red '96 came to us missing the spring, so it got one of my redneck engineered ones as well.
The spare timing belt stayed on the wall of my garage longer than the Escort stayed in my driveway and has been used for several projects now.
Please ignore the salt & dirt. We've been having a bit of weather.
Tooths 1 & 2 are visible. The left and right 1/3 of the space between tooth 2 & 3 are removed. Tooth 3 top on left & right 1/3 (belt base is still there) are removed. Then it is just tuck and twist. Never failed and never fallen off. No glue used or needed.
