gas cap
Nashvegas
Can any one tell me what years this gas cap could of come on?
It's on my '71. I thought it matched the early hub caps. I have had the truck 5 years and just noticed the emblem on it.
The 71s, (and prob a few others right around then) have a chain, the earlier ones do not. They are available new.
It's on my rear tank. I was just trying to decide if I should take it off the truck so someone doesn't "borrow" it.
lingo said:
It's on my '71.
Where is that fuel filler located? That does not look like a stock opening for a 1971....
Is this the filler for an aux. tank? Could very well have an earlier filler neck....
All the early cruisers in this country came with the chain on the gas caps. On the FJ25 soft tops the chain was attached to a extension that was pulled out using the chain. The radiator cap and oil fill cap both had chains too. The oil fill was dropped with the F155 in the 1972 model year when the oil fill was move to the valve cover, not sure about the radiator or gas cap, probably around the same time.
John
John
My FJ45 doesn't have the little tab with a hole on the gas filler neck to attach the chain to like the FJ40 has. I think that's why the caps come with and without chains (different P/Ns, IIRC).
Poser said:
So is this cap identical to the other?
No the factory tank was removed and they left the fill neck on the truck and put a locking gas cap on it.
