Gaps in door advice
Website
www.geocities.com
I have finished putting together my truck, but I have some significant gaps between the doors, bought the fiberglass rear doors from SOR, but they did not fit well at all. The weather stripping does not nearly cover the gaps in the rear (upper) hinged door between the truck and the door. The two front doors have spaces that I can look through despite the weather stripping. I have tried bending the doors, but that does not seem to work. I'm not sure what to do, how do you guy's get these things to seal?
MY rig is a 1970, FJ40. I did a search on weather stripping, I bought the SOR OEM replacements/replicas. I find the weather stripping to be of decent quality, but I just can't get the big gaps filled.
Any thoughts?
Can you take some pics and show us exactly where the gaps are?
Is your tub rusted in the rear? Best guess would be the tub has sagged. Take a strong ratchet strap and attach it to the inside of the tub right above the wheel wells. Slowly tighten it pulling the tub together and see if the gaps get better. If they do it may be time for new body mounts or some body work.
You might check the door hinge alignment. If your top hinge is mounted out a little, you might find the door sticking out further than it needs to. I've had my Fj55 doors off and on a dozen times in the last week doing bearclaw latch conversion and I've found that the hinges adjust quite a bit. It takes a little fiddling to get things to fit the way you want.
My $.02.
