Gamiviti Rack on 200-series
I believe that the 200s have the little channel up the windshield similar, if not a tad bigger than the 100. I remembered that I have covers on my LX that keep trying to pop off on the driver's side... need to look at that again...
Sounds like a good idea. How did you run the wiring into the interior? Did you feed it down through the tailgate somewhere?
I run it down the front passenger side inside the rubber lip alongside the windshield since my spod is above that side's firewall grommet. Sorry I'm in a different country than the 200 at the moment so can't snap a pic for a bit. I also used these but with good 3M outdoor double sided instead of what they came with:
http://smile.amazon.com/dp/B013IMSOFO/?tag=ihco-20
and iirc:
http://smile.amazon.com/Scotch-Permanent-Outdoor-Mounting-4011-LONG/dp/B000BL5INM/?tag=ihco-20
I encased the (4) 16ga wires that came with the Rigid SR-Qs inside a 3/8" techflex:
Amazon.com: TechFlex F6 Woven Wrap 3/8" 10' Wiring Split Wire Covering F6W0.38BK: Home Improvement
And ran that down through the shut line between fender and hood. I used another tie base in the space under the hood to keep everything secure. No abrasions this way so far.
These are dups to things I posted elsewhere but this much wire/wrap is no problem through there IMO:
dDFmJNBC_cxdYE64XXKP7qr87hFPZSJV4BPIPM_e_6MrBqXuA3CJ9YMhvs8DkzqoNKQe3WxHDX_V1ZlD1UwJ41_33O8olTvdh8YHes3Qgt_KVzQKrUyeOo8fGcnNhQr8u1CnlwcG547VTUrw-n2VGME2Rffv3g3S0cH3DQ_V_FdCzhrJDLMtIwSrF02TvZYdx8hE7p6doi58S_Vai36nMRPTKk_JMwGUVzvNeAyOOJrLbuVmEx5h5Gx2c3zVBhzK0q76WbwE0r6-CCPAoFxNxj8LFQxA6_c5f_m-CtTtW_p8sdoeNlGCNAMUOq0MPcyRLehxbP8dm3x5Cr0R0b4CutIeBUu1l38r2bYvAHGGdp3Xire36SyAPSYCPeK9gLYh137cH63YKoMeChr0aSZx25mT1JAlMt5uTsnIOV7OIrdmd77yn5a4wcJpr_pchYmK9iVYgJ8b-pgELAlfMbd3fsrzy2mcgIMvSnIquqBKkWl-_bdsOYgNqVwc78wBlfuyJBVaM7XWBg4D60pOnGXH7dYJtGD51dNU1joTdeNqDLBsWnST5SJhpOQPjb_J5Gs=w645-h860-no
677x41yDbschAm31M462UfIJhhWkLkqVZ59Y9CEt8XC67HWKS8Hr4q4j4s-QhZNUQmn1boJ9TM1Herr2ZJMMEpnbJgaewXf1qJ6XKuV_XbfSdhjuc0Es3Dd6bHHA6I0DAe79KpLwU18ZcG7aFKgQgzwT6teMRO_4MIHvaq3IQHN5BNt1sDkqapz1CWf4v1VwO5Tfumz9BQIhcPGFdiezLs19MfAO-dFwtbbNdiBI_hlZKcjTG2yYeQoeROjXOzz9qj_13VMLGQ3Ly2SM_Kjeb_cb3VM-IRjhnUKUwdB4PTsQC7p546sKaa36NCtDEUAh_fNC75Hz4NJZkxZ6I-XgQFVG12cdZIICtNkolo-BQS5wJ2k8zXNXslbsrl1bNN7VGQejvaWNBvUN6D4YJQxLCUmV1tOomsygU-h3YEyAHcX76c2ytqU_Y2Pov26TkX9bMenyzZrh8e-KXQwVK8cHdcJKVcmQxVAuCIpArpRGBSv50aGbQe2AwRd17MOkc-7xyUXJhqpTjc1agY8Jfdio5-LC9-0M_T-EJokF3DEjEAY71t5FcQN-PkTQ8qw_MEo=w1147-h861-no
I've been slow to update, but I finally got the lights that @nakman supplied wired up this weekend. Now that I consider my rack complete, I've got a few photos to share.
Tim, let me know if you'd like some higher quality photos for your website.
Anyone have an Expo+ rack? I have the expo on my 100 and would like the rails back a little further to aid when climbing around the truck.
Not sure if I want the + or the ++
Talked to Tim tonight and ready to finalize but hoping someone has a pic or two!
I have the same version as @linuxgod's above and regularly use the bars as a brace while standing on the rear tires and sliders. It's quite convenient. It would make managing a RTT a little difficult. I had a Tepui and then later a James Baroud on mine and had to access the mounting points from the rear of the vehicle and the sunroof.
