FZJ80 rear backing plate part search.
The unmarked stud/bolt (shaft) is 12mm (diameter) and the flanged nuts are 17mm so go by the FSM? (Edited for future searches)
Wait for others who actually know to chime in ;)
Checked the section (pg 39-40, 96 FSM) which discusses Standard bolt and stud marks relating to their respective Class but couldn't find any markings on those stud/bolts.
FWIW added photos for reference:
If there are no marks in the fasteners, you have the torque specification. There are standard values for unmarked fasteners, based on size, just like the marked ones.
I saw that, no marks seem to make it a 4T so 39ft lbs (for a hex head), no mention of a cap head bolt (but then an unmarked stud is also 4T). I've never had that area apart so just guessing but the (thick) cap head likely has a squared off shank just under the cap head to help lock it in place while the nut is being tightened down, so would that change the torque specs?? Also, the flanged nuts are fairly beefy like the nuts for the driveshaft flanges. IDK.
@Kernal What did you end up going with for torque? The FSM reference the part as "Backing Plate" but never shows the torque for those nuts.
I just removed those nuts from my old axle, and they weren't very tight. I am thinking of 39-ft lbs should be appropriate.
I have not had the rear backing plates off so haven't had to tighten those bolts. Try pinging the others in the thread that were working with those components.
