eBay FZJ80 Pocket Flares 93-97
Texas
These pocket flares will fit any 80 series truck, but this set is made so that 93-97 mud flaps will bolt up.
They are made with fiberglass and high quality flexible resin so that they are very durable and flexible. The consensus I have observed is that the most common cause for the stock flares to fail is the internal fastening tabs breaking off. These flares use fastening hardware through the pockets to mount securely and will not separate due to broken tabs.
IF a flare is damaged it may be repairable (broken tabs on the stock flares are not repairable) or a one off replacement flare may be purchased. The flares include Torx hardware, gaskets, and they are primered flat black.
$650 plus shipping per set.
Your cruiser looks a little different from the last time I saw it! You going flareless or what?
I took the stock flares off and switched to pocket flares like in the pictures.
I don't do the physical work. I had the idea, paid for the materials, and I hired a guy that does fiberglass for a living to make the molds. I have the same guy use the molds to make the actual flares.
Thank you for the kudos!
Those look great but too rich for my blood. I love the look they give the truck!
Like em.
Hi jamisobe,
I am the ARB Dealer in the Dominican Republic. We have a lot of problems with the flares flying off the LC's So, it is possible that there could be an interest in your flares here in the D.R.
I am interested in trying a set on my 93 LC, do you use the stock mud flaps ? Or do you customize them too ? How flexible are your flares compared to stock flares ?
Thanks,,,
Manny
by the way, the flares look awesome in the pix's !
Hi jamisobe,
Thanks,,,
Manny
Thanks Manny,
I am still making these and I have sold 8 sets so far. They do work with the stock mud flaps, but I reccomend trimming the mud flaps by at least 2 inches to avoid rock grab when backing against rocks. The flares offer some flex, but they are not impervious to damage. What makes them durable is that they are bolted on through the pockets and there are no fastening tabs that can break off.
I sent you a PM...
