Hi folks. I'm hoping to learn from someone's experience with the plastic cable running from the antenna mast to the motor. I read that late 96 and 97 models have a toothed cable and prior models have a smooth cable. Can I use a toothed cable in my 94 model? Is the motor drum or feeder mechanism designed differently so that I need to stick with a smooth cable? I haven't found the mast with smooth cable combo for sale, only the toothed version. My motor makes noise so I'm hoping to avoid an expensive project. Also, I'm still not sure if I can feed the cable down the tube and expect it to catch in the motor drum or not.
Thanks much for any help.
