- Thread starter
- #41
Ok here’s a video of the first start attempt. This was a genuine first go but I did crack the injectors lines first to check I was getting fuel and reduce cranking time.
I had also already cranked it a fair bit with the spill driver unplugged to get oil pressure up (came up to 35psi just in the starter). There’s no dash still just a mechanic oil pressure gauge. All that is still to come with fitting the update dash to the car without loom swapping...
The conversion is still far from over but I feel much more relaxed about it now I’m over the first major hurdle. With some help via email I’ve done all the wiring myself so far and now have a pretty good understanding of the whole management system, even if there are a few unknowns to do with the transmission signals...
I could go into a few wiring details if anyone’s interested? But for the moment my main question is regarding the neutral start switch/signals: what happens if you drive an auto ecu while the NSW signal to the ecu tells it it’s still in p or n? A diagnostic document suggests it’s adjusting afr to optimise Idling. But it’s also getting a signal it’s in D (now hooked up to the clutch switch as is correct in any manual ecu). Has anyone experienced running issues like this? Brian at PDI assured me from experience it would be fine but the diagnostic doc sort of contradicts that!
