Time to resurrect this thread. Last fall I burned up my fusible link on a fairly steep incline. Originally I had replaced it with just a standard fused wire and put a 5A fuse in there. The next steep incline I was on it blew that fuse. After much discussion on the pros/cons of replacing the fusible link with a standard fuse I was convinced I needed a new OEM fusible link. So I got a few from Wit's End.
So, today I was on another fairly steep incline (maybe 20 degrees) and the same thing happened again. The engine bogs down like it is going to die regardless of my coaxing of the skinny pedal, engine dies, check fusible link. Fried.
So I still had the old fused wire and another spare fusible link. I decided to throw the fused wire in. Burned through a 10A and 15A fuse on the same incline. Does not seem to matter if it's in 4H or 4L same exact thing happens. I actually had to have a buddy tow me up the steep incline and then once on the flat it runs with no issues whatsoever. Additionally, it is always the smaller (makes sense) pink wire in the link that burns up.
Does anyone have any ideas what could be drawing enough current when going up a steeper incline to consistently draw at least 15 amps and burn a fusible link??
Any help/ideas would be greatly appreciated, as my typically bulletproof Search & Rescue vehicle has been rendered useless on anything but flat terrain.
