Order the fuse block and jumper kit. You will also need some 15 amp and 20 amp ATC blade style fuses.
Disconnect the battery: Both + and -. You have been warned!!!
Remove your OEM fuse block from the firewall. One side of your OEM fuse block is the "input" There will only be two wires on this side, one straight from the alternator power feed circuit (white wire/blue stripe). (This wire is ALWAYS HOT and feeds the headlight/brake/hazard circuits.) and one black wire from the key switch ie the key switched feed. This feeds the turn signal and other circuits that are only powered when the key switch is in the on position. Lets call the side with only two wires the A terminals and the other side the B terminals.
The Blue Sea fuse block has 6 terminal on each side. Choose the side (make it the same side as the OEM or the wires will not reach!!!) you want to be the input side. This will be the A terminal side. Install four jumpers as follows: Assume the top is Terminal #1A. Install a jumper from Terminal #1A to Terminal # 2A. Then another jumper from Terminal # 2A to Terminal # 3A. Next install a jumper from Terminal #4A to Terminal #5A, Then install a jumper from Terminal # 5A to Terminal #6A.
Now remove the White/Blue wire from the OEM fuse block and install it on Terminal #2A. Now the White/Blue wire is providing power to the top three fuse positions. Remove the Black wire form the OEM fuse block and install it on Terminal #5A. Now the black wire is providing key switched power to the bottom three fuse positions.
Now remove the wires on the other side of the OEM block one at a time, and place them in the same terminal position on the Blue Sea Block B side. You will notice that Terminal #3B on the other side is not used in most cases. It is a spare fuse and you can power things like a radio from that fuse. Use a 15 amp fuse here. Refer to the FSM for what size fuses go where. I'm not in a position to look that up for you...
Note: The Blue Sea 5035 comes with a cover and blank labels. Use a permenent marker to write on the labels, then affix them to the cover so you will know what fuse protects what circuit.
