funny/odd notes in service history
NC
I've been searching for a '13-'15 LX so have looked through dozens of service histories on drivers.lexus.com. Noticed something today I've never seen before, an entry for a speeding citation. I imagine that means the tech was test-driving before/after service and got a ticket? Anyone seen that before? What is the oddest or funniest thing you've seen in a service history?
JTJHY7AX3D4096976
SERVICE: BALTIMORE COUNTY MARYLAND SPEED CITATION# 744503 10/17/12 11:08AM 1600 BLK OF CR
DESCRIPTION: BALTIMORE COUNTY MARYLAND SPEED CITATION# 744503 10/17/12 11:08AM 1600 BLK OF CR ~|~BALTIMORE COUNTY MARYLAND SPEED CITATION# 744503 10/17/12 11:08AM 1600 BLK OF CROMWELL BRIDGE RD S/B ~|~ ~|~5586 BALTIMORE COUNTY MARYLAND SPEED CIATION#744503 10/17/12 11:08AM 1600 BLOCK OF CROMWELL BRIDGE RD S/B SHOW LESS
That is funny. Whats even funnier, that address is for the High School that I graduated from in 1977 (Loch Raven High), and I grew up about a mile from there. I can report that road is heavily patrolled, as its an awesome windy road to drive rather "spirited", shall we say. I drove that road many times, but somehow never got dinged.
I too know this place! I worked as a college intern just a mile up from LockRaven High school. I used to commute back roads from Bel Air and can attest that road is fun! Maryland is crazy with speed cameras all around.
In my search for a LX570, came across this service description. I'm new to Lexus, so I'm curious. Can anyone confirm that the hot sauce treatment is in the Service Manual?
That's a CYA notation from the service advisor. After the floor mat issues he/she is protecting themselves and the dealer.
Ha! Here's a note in my recently purchased 2018 LX of the previous owner:
6534 miles​
DATE: 11/2018
Service: REMOVED BOTTLE, NO FURTHER NOISE HEARD.
description: REMOVED BOTTLE, NO FURTHER NOISE HEARD. ~|~CUSTOMER STATES THERE IS A NOISE UNDER THE DRIVERS SIDE SEAT, SOUNDS LIKE SOMETHING IS ROLLING AROUND. SEE DON. ~|~ROAD TESTED VEHICLE, HEARD NOISE COMING FROM A LOOSE WATER BOTTLE ROLLING AROUND ~|~REMOVED BOTTLE, NO FURTHER NOISE HEARD.
Life's hard. It's even harder when your stupid.
I saw this one on a vehicle I was looking at recently:
SERVICE: CAN FEEL A VERY ROUGH IDLE AND HEARD A LOUD METALLIC NOISE FROM UNDERNEATH VEHIC
DESCRIPTION: CAN FEEL A VERY ROUGH IDLE AND HEARD A LOUD METALLIC NOISE FROM UNDERNEATH VEHIC ~|~CAN FEEL A VERY ROUGH IDLE AND HEARD A LOUD METALLIC NOISE FROM UNDERNEATH VEHICLE CHECK AND ADVISE ~|~DAMAGED TO FAN SHROUD CAUSED BY US ON LAST SERVICE. ~|~BATTERY COVER FELL OFF AND HIT THE FAN SHROUD CAUSING DAMAGE. REPLACED RADIATOR AND FAN SHROUD AND BATTERY COVER, TEST DROVE AND VERIFIED REPAIRS
That owner had the worst luck. Same vehicle:
August 2020:
SERVICE: ENGINE
DESCRIPTION: ENGINE ~|~UPON INSPECTION TECHNICIAN FOUND THAT THERE IS A LEAK UNDER THE INTAKE MANIFOLD ~|~ ~|~RE-SEALED ENGINE VALLEY PLATE.
October 2020:
SERVICE: CYLINDER HEAD GASKET
DESCRIPTION: CYLINDER HEAD GASKET ~|~C/S: VEHICLE HAS COOLANT LEAK. RECENTLY RESEALED V ALLEY PLATE AND REPLACED WATER PUMP ~|~GUEST STATES THERE IS A COOLANT LEAK. VERIFIED CONCERN, FOUND WATER PUMP REPLACEMENT AND VALLEY CORE RESEAL DONE CORRECTLY. FOUND RADIATOR TANK SEPARATED AT TOP END. REPLACED RADIATOR AND PRESSURE TESTED COOLING SYSTEM. FOUND COOLANT LEAKING INTO CYLINDER ~|~REPLACED HEAD GASKETS. SENT HEADS OUT TO A MACHINE CHOP. THEY ARE OKAY. FOUND ENGINE BLOCK IS STILL STRAIGHT. RE-ASSEMBLED ENGINE. VEHICLE NOW RUNS CORRECTLY. 9 QTS. OF 0W20. OPCODE: 110051, A T1 66 T2 13
I doubt hot sauce on the wires would last very long, but Honda does sell a special "rodent tape" that is supposed to have capsaicin in it, the hot part of peppers. Not cheap but it's supposed to work really well.
I thought they put the hot sauce on the squirrel.
