Fun on a Wednesday night
Dayton, OH
Well tonight I dug into a few small projects on the 80.
First on the list was to replace the power antenna which was in bad shape. That turned into a little bit more than I had thought. After about an hour and a half the new antenna. By following the great instructions at this site - Power Antenna Mast Replacement
But what a difference, if you need to do it, call CDan and get it done, you will be thanking yourself later.
Then I moved on to the fun project. Replacing several of the switch lights and the lights in the HVAC control center. This is a fairly straight forward project. The HVAC control center comes apart easy enough and the three lights are a quick fix. While I was in there I clean the temperature sensor which was covered in a very thik layer of dirt. I am not sure how much it will help, but every little bit helps. Now all of my dash board lights are bright and beautiful for the first time since I bought the rig last Sept.
I also changed the oil. Very exciting!
I posted earlier about a new radio I attempted to install with no luck. See here - https://forum.ih8mud.com/80-series-tech/253358-rth-factory-radio-install.html
I am not sure what the deal is, but if anyone has any thoughts I would appreciate it.
Happy Thanksgiving!
An update on the HVAC work I did last evening. It seems that the heat only works above 80 on the controls. I am not sure if by cleaning the temp sensor it may have messed things up.
Thoughts?
Also, there is a white flex hose located behind the unit that seems to go no where. Does anyone have any knowledge about this.
The HVAC system was working good prior to the bulb replacement, however I don't think the temp sensor was plugged into the appropriate location and it was very dirty.
The rig in question is a 97' 40th Aniv. Ed. which has the Auto Climate Control.
Thanks and Happy Thanksgiving!
The flex hose is the internal air temp sensor. If you don't have it plugged in (there's a spot on the HVAC control unit for it) your temperature gauge won't work properly.
Also, make sure you have all the cables plugged in properly. IIRC there should be two, and if one of them is unplugged or not plugged in all the way you'll experience some of what you're seeing.
Ebag333, thanks for the tip, I will head out later and take another look at that. Hopefully I can get it back to normal.
